I have a big problem localizing my setup.
If I have a statement like "Set Variable X to 5" and translate the setup to e.g. german I will get the value 5 with english or german langugae.
That's ok so far.
But now I have to change the value in the script from 5 to 10 and rebuild the setup.
Now i will get the value 10 using english, but still get 5 using german.
This is caused by the translated "Set Variable Command" in the language mapping.
How can I disable the translation of "Set Variable Commands"???
It's not possible to export the whole script again and override the already translated texts for just a variable value which is part of the scripts algorithm! If I export the languages again with keeping the old translations I'll never get rid of the old values!
Please help!
cew3
How to disable 'set Variable commands' for localization??
copy paste delete
What I usually do is copy and paste the command and delete the original. That way there is no translation for the new command until the next translation run.
It's a pain to always remember to do this whenever you change a set variable command.
There are some options regarding how the commands are translated, but I didn't find enough documentation to give it a try. And I didn't have the time so far to experiment.
Rgds
Richard
Rgds
Richard
