Problem with debugging
lewisv
Post by lewisv »
I am testing the application out.
I am trying to debug msi code.
It keeps giving me the message. "Please make a debug build of your project..."
I can see when I compile it is putting it in the release directory.
How do i switch the compile to debug mode?
dbrillon
Post by dbrillon »
If you use InstallAware 8 you need to:
1- Select Project settings from the main menu
2- In the Project Options windows click on the Build node
3- Check the option Debug build
lewisv
Post by lewisv »
that did it thanks
