File Associations
Jupiter
File Associations
Post by Jupiter »
Design/Setup Architecture/File Associations.
I add my extension to the table and set up the association. Then I build the project and run my setup. After the setup has completed the association does not work! In the Registry I found an entry with my extension but it seemed empty - no executible is assigned. Help please.
ulrichard
Post by ulrichard »
http://www.pointline.com
http://www.paraeasy.ch
http://ulrichard.ch
Jupiter
Post by Jupiter »
did you assign an open verb?
Indeed I missed this one. Now it works. Thank you!
