How to run InstallAware 8 without UAC prompt under Vista
pqbob
Post by pqbob »
I run under a Vista account that is a member of the local Administrators group. I have UAC turned on, which means that when InstallAware (miae.exe) starts I always get the UAC elevation prompt and must elevate in order to run InstallAware.
The attached HowToRunInstallAwareAsStandardUser.doc explains the steps I took to allow running InstallAware without getting the UAC elevation prompt.
I started down the path of getting InstallAware to run as a standard user because I keep my InstallAware projects on a network drive that gets mapped to a drive letter in my login script. When InstallAware forced me to elevate privileges, the elevated InstallAware instance did not see the mapped drive. Thus I wanted to be able to run InstallAware as a standard user that could see the mapped drives.
After I got InstallAware tweaked so that it ran nicely as a standard user, I found the following Microsoft knowledgebase article that explains how to tweak Vista so that the elevated user token sees your mapped drives.
http://support.microsoft.com/kb/937624
HowToRunInstallAwareAsStandardUser.zip
ulrichard
Post by ulrichard »
Hi pqbob,
thanks for the information. Begrudingly, there are also some problems with "linked connections":
http://www.installaware.com/forums/viewtopic.php?t=4110
Rgds
Richard
http://www.pointline.com
http://www.paraeasy.ch
http://ulrichard.ch
