Log file before Apply Install
JeffTucker
Post by JeffTucker »
Is there any way to write a running log file that doesn't depend upon getting beyond the "Apply Install" command? For the situation where there is a silent install and something goes wrong before the Apply Install, there is no trace on the user's disk.
I tried WriteFile, but that has the same characteristics as a log file.
At what point are files actually copied to the targetdir? sometime after the Apply Install, but when? I need to run several piggyback installs after the files get to some temporary install/app1, install/app2 directories.
Fiddling with technology
You can write to any text file you like using Write to Text File.
You can determine the log file name using the list of pre-defined variables in help.
Read the help topic titled "setup commands preceding apply uninstall" for more information on your Apply Install question.
