sathishmca
Posts: 17 Joined: Sat Apr 18, 2009 12:33 am
Post
by sathishmca » Tue Apr 21, 2009 3:26 am
Please Explain me the process, how to add a serial number in the setup file.
Thank you,
bokkie
Posts: 767 Joined: Sun Feb 08, 2009 6:30 am
Post
by bokkie » Tue Apr 21, 2009 4:47 am
There is a sample project file in IA called Serial Validation . You can use that for ideas on what to do and it contains sample code to get you started.
sathishmca
Post
by sathishmca » Tue Apr 21, 2009 8:02 am
Thank you for your reply
I have another doubt
i want to set the serial number to only one system. if i installed in one system and i try to installed in another system, i want error message.
is this possible
sathishmca
Post
by sathishmca » Tue Apr 21, 2009 10:49 am
i get a serialnumbervalidation sample project in IA
and i run the project , it ask the 25 digit serial number
where to get a 25 digit serial number and can i give the serial number my own numbers
please reply me soon
Posts: 3452 Joined: Thu Dec 22, 2005 7:17 pm
Post
by MichaelNesmith » Tue Apr 21, 2009 1:02 pm
Please read the comments in the sample project, its all explained there.
sathishmca
Post
by sathishmca » Wed Apr 22, 2009 3:05 am
thank you for your reply.....
is this possible to set a serial number in a single system
tommykjensen
Posts: 29 Joined: Fri Jan 16, 2009 11:56 am
Post
by tommykjensen » Fri May 01, 2009 3:16 am
Yes if you validate the serial online. See this post
http://forums.installaware.com/viewtopi ... ght=#14587
You would need to modify the php script to record that the serial number has been used already. My sample script only checks if the serial is valid. I have added a few other things in my script which I for obvious reasons won't disclose.
