Hello
Is there a way of knowing that the installation is actuallly being run as a download from a web-site, rather than simply a Web Install being run from a network share or CD. I need to know this to allow the installation to download some additional files from the location of where the web-install originated. Cluctching at straws here.
Anton
Determining type of Installation - Web Install
asparagusx
asparagusx
That is a very good suggestion, however, when it is a web download, the EXE seems to be copied to a temp folder - which variable can I check for the original location of the file. $SFXPATH$ and $EXEPATH$/$EXEDIR$ contains the 'local' temp path. I am trying to get the URL (if any) from where the install was downloaded (at runtime).
Anton
Anton
Please check the list of pre-defined variables for extensive startup variables that indicate where your setup is running from, whether it is a web install or another install, etc.
However, I don't think you can detect the download URL using this method, as even with a web build, the install is first downloaded locally - and that local location will be what you get.
Note that you can use multiple download URLs and variables in your Web Media Block commands - that might help too
asparagusx
