Error code #2753 while installing on WinXP powered notebook
SergiiGulenok
Post by SergiiGulenok »
Hi!
We are experiencing one strange error while installing software on one notebook powered by WinXP. It says:
The installer has encountered an unexpected error installing this package. This may indicate the problem with this package. The error code is #2753
I'd like to ask what does this error code mean and would appreciate any help to solve this issue. The error occurred after uninstalling the older version of our software and while installing the newer one. We used InstallAware Developer 8 to build the installation package.
Thanks in advance.
neillans
Post by neillans »
The error code refers to a error code received from the MSI Engine (Microsoft) -- have a look on MSDN for the error meaning.
Andy Neillans
SergiiGulenok
neillans wrote:The error code refers to a error code received from the MSI Engine (Microsoft) -- have a look on MSDN for the error meaning.
Thank you!
HAHNmediaservice
Re: Error code #2753 while installing on WinXP powered noteb
Post by HAHNmediaservice »
We also encountered this error on a maschine (not notebook) runnig Windows 7:
Whether installation nor uninstallation works, always Error 2753.
We already tried:
(1) regsvr32 vbscript.dll => no effect
(2) Windows Installer Cleanup Utility => no effect
How to get rid of that? Any help is welcome ...
HAHN mediaservice
Inh. Irena Hahn
Seif-Wald-Ring 26
54329 Konz-Roscheid
Tel: +49 6501 6 03 96 79
Fax: +49 6501 9 22 31 29
Post by mills »
Here is a description of the error:
http://www.appdeploy.com/msierrors/detail.asp?id=279
Are you installing a service that may already be running?
http://www.davidov.net/blog/index.php?/ ... inter.html
Can you identify a folder that you cannot delete?
http://forums.sun.com/thread.jspa?threadID=5331236
Will your software successfully, completely uninstall, then reinstall?
http://www.computerhope.com/forum/index ... ic=84552.0
HAHNmediaservice
Error 2753 could also be an inaccurate merge module, see here for some more information on that: http://www.installaware.com/forum/viewt ... 931#p21513.
HAHN mediaservice
Inh. Irena Hahn
Seif-Wald-Ring 26
54329 Konz-Roscheid
