I noticed that default installation marks app as SystemComponent in the registry (under 'Uninstall' registry folder).
- Is there a reason for this default behavior?
- If I wanted to set SystemComponent to be false, should I explicitly overwrite that value in my installer script or is there something I can set that would prevent my app from being marked as SystemComponent?
Alex
Default installation marks app as SystemComponent in Regis
alexzakharov
alexzakharov
Writing the key expicitely doesnt work either
While I was waiting for reply I try writing SystemComponent key myself with 'Write Registry Key' command - I set it to zero but is still shows up as 1. What gives?
Much thanks,
Alex
Much thanks,
Alex
