.NET Version 1.1 and 1.1 SP1
gweihs
Post by gweihs »
If i use "Check/Install .NET check V1.1" , what value will it return if:
1) Version 1.1 is installed
2) Version 1.1 SP1 is installed
is it true for each or true for 1 and not for 2
True for each.
Gizm0
Post by Gizm0 »
If you check for 1.1 SP1 and 1.1 is installed, it will return false,
if you check for 1.1 and 1.1 SP1 is installed, it will return true.
Panagiotis Kefalidis
Software Design Team Lead
