Folders and subfolder uninstall
MichaelM
Post by MichaelM »
Components that contain subfolders are not being uninstalled when the application is uninstalled. I verified that the check box to leave the component installed when uninstalling is not checked.
How do I get IA9 to removes these folders when uninstalling?
Re: Folders and subfolder uninstall
Can I see a screenshot of this please?
MichaelM
Post by MichaelM »
Attached are the images. Note that my setup has components that merge folders with one another. For example in the screen capture you can see the following folders in "C:\Program Files (x86)\DataView\Config"
GroundTester
Megohmmeter
Qualistar
Simple Logger II
Wattmeter
Each of this is from a different component.
MichaelM
Post by MichaelM »
I got it to remove the install folder (and subfolders) by adding
Recursively Delete Files $TARGETDIR$\*.*
command before the Apply Uninstall operation.
