Is it possible to open a dialog by an button? (like the browse button)
I've tried a lot but did not find any solution.
Thanks!
Opening a dialog thru a button
Please take a look at the CD Autorun sample which illustrates how to custom-process clicks on dialog buttons. Note that you cannot nest dialogs, however if you wish to show a file open dialog etc, check on the plug-ins section of this forum - there is a plug-in there that does exactly that, contributed by our MVPs.
Re: Opening a dialog thru a button
Treoxx wrote:Is it possible to open a dialog by an button? (like the browse button)
Thanks!
Of course you can!
Please use the Display Dialog command.There is a good example also on the MSDN Article, explaining how can you use buttons on your dialogs.
If you need further assistance, i can provide consulting services and create the setup for you, at very a reasonable fee.Feel free to contact me at pkefal (at) installaware (dot) com.
Thank you!
Panagiotis Kefalidis
Software Design Team Lead
Users browsing this forum: No registered users and 20 guests
