checkvc91_x64 error (2)
steven
Post by steven »
I've a PC with a Clean installation of Windows 7 x64 .
Using my InstallAware Studio 9 ( Moya SP1 ) I've added to the Default Project Sample the prerequisites Microsoft Visual C++ Runtime 9.0 (includes ATL and MFC) Service Pack 1 (x64) . When I try to install the pkg the InstallAware wizard start to install the runtime requirenment but the procedure fail and a MessageBox suggests to use Windows Update to install this update.
I've found a lot of problem using the x64 script, but my version of InstallAware is certified for Win7 x64 ?
There is an upgrade available ?
There are new Microsoft Visual C++ runtime that i can install without problem ?
Steven
Re: checkvc91_x64 error (2)
Post by mills »
Could you upload the project you made?
Also, please provide as much relevant information as possible:
Develop System
What version of IA being used?
Windows version
(UAC settings for Windows 7)
Type of project they’re using.
PreReqs they’re using…
Plugins being used?
Install System
Windows Version
User rights
steven
Post by steven »
Ok,
below the info required and in attahc the ia project :
Develop System
What version of IA being used? IA 9 Studio ( Moya .Sp1.070409)
Windows version Windows 7 Ultimate 32 bit
(UAC settings for Windows 7) UAC enable, require Administrator
Type of project they’re using. Your Default Project
PreReqs they’re using… MS VC++ Runtime 9.0 SP1 (x64 )
Plugins being used? None
Install System
Windows Version Windows 7 Ultimate x64
User rights Administrator
I use the default project as example , the problem is the runtime installation and happen only on Seven 64 bit .
Steven
Default Project.zip
(415.63 KiB) Downloaded 1475 times
Post by mills »
Please install the latest version of InstallAware: Version: 9.1, Service Pack 3 (build Moya).
Rebuild and try again...
Post by mills »
I tried to reproduce this twice:
Attemp to Reproduce:
Start new Blank project.
Include runtime MSVC++ 9.0 (includes ATL & MFC) SP1 (x64)
Build project. (single file)
Run installer on Windows 7 x64 (+UAC)
Asks to install VC++ runtime. Click Next.
Displays "Plese wait while installs requirements"
Shows status:
copying files (dlls),
publishing product info
Result:
C++ runtimes successfully installed.
Verify by canceling setup when installer dialog displays
"will install <setup> onto computer".
Run setup again, notice the prereqs prompt doesn't
display again and goes straight to product install
prompt.
Notes:
Web deployment didn't work; couldn't download data, but
got no prompt for Windows Update.
Tried sample project provided by customer, same
essential project- barebones with C++ runtime checked.
Result:
Runtimes properly installed
steven
Post by steven »
how can upgrade my Version ( IA 9 SP1 Moya ) to the version that you suggest ( IA 9.1 SP3 ) ?
I hope it is free......
Steven
Post by mills »
You can get it from our download page:
http://www.installaware.com/downloads-p ... nloads.htm
You can upgrade at no additional cost.
AKNG
Post by AKNG »
Hello Mills,
I have exactly the same problem as Stevens. In my case, i don't have any UAC enable. And I'm using InstallAware 9 R2 (Build sliders.rtm.050709)
Can you send me the link to download the SP3? I really need to install those C++ runtimes for 64-bit version.
Thank you
AKNG
giaviv
Post by giaviv »
AKNG,
Have you considered switching to InstallAware 10?
InstallAware Support
AKNG
Post by AKNG »
Yesterday, I tried the version 10 that I downloaded at December 1st, but I still unable to install those C++ runtimes. And the error message is in Vietnamese, so I went back to version 9 R2
Regards,
giaviv
Post by giaviv »
You cannot use the same license on all InstallAware versions. When you upgrade InstallAware (whether its a minor or a major upgrade), you must regenerate your license and reinstall it. For example, you cannot use the same license in version 9 R2 and in version 10. Furthermore, in general, message boxes and texts in unfamiliar languages mean that you have broken your IA product by using an incompatible license.
AKNG, please see this forum post regarding your run-times:
http://forums.installaware.com/viewtopic.php?f=2&t=6174
Thanks!
Frank
Post by Frank »
I have the same issues with checkvc91_x64 and I'd like to download IA9 SP3.
The link in this thread point to a download page for IA10. Where can I down IA9 SP3 please?
giaviv
Post by giaviv »
Dear Frank,
Unfortunately, we do not keep old versions of InstallAware on our servers. Please try this thread as you might find it helpful:
http://www.installaware.com/forums/view ... f=2&t=6189
joakes
Post by joakes »
We had the same issue but using IA10.
On a particular customer's system, they were using an odd configuration.
The processor was AMD64
The OS was Windows 7 (32-bit).
VC90 errored out.
Error 1935. An error occured during the installation of assmebly 'Microsoft.VC90.MFC,version="9.0.30729.1"
ProcessorArchitecture="amd64", type="win32"
HRESULT: 0x80070091
No solution as of yet.
giaviv
Post by giaviv »
Dear joakes,
Please take a look at this thread and let me know if it helps you.
