I'm running InstallAware 9 (Build Moya.sp1.070409). That's my situation:
I've go a software version 7.0.0 (that's what I've filled in in "product version"). I set up a monitor url (http://www.abc.com/ftp/updates/updates.ini) and created a setup which has been delivered to customers.
Now it's time to deliv version 7.0.1. I changed the "product version" to 7.0.1, added new files and so on. After that, I added the old setup from 7.0.0 to Deployment -> Patches and created a patch via Project -> Patch. The patch itself works fine.
I added a update pack ("Web Updates"):
Name: Update to 7.0.1 from 7.0.0
URL: http://www.abc.com/ftp/updates/installe ... _7.0.1.exe
In "Web Updates" > "Version" I added the version 7.0.1 and assigned the created updatepack to it. So I got following updates.ini:
[Update Packs for Versions]
7.0.1=Update to 7.0.1 from 7.0.0
[Update to 7.0.1 from 7.0.0]
URL=http://www.abc.com/ftp/updates/installers/Update_from_7.0.0_to_7.0.1.exe
Description=
Reboot=No
Silent=No
Parameters=Do you have any ideas?
Greetings from the Black Forest
