I think it must be simple, but I do not know how to do
If have a dialog "destination" (like from the example project) with a text field called "DataDir" and below a treeview
I want that at start time if the dialog appears the text field is empty.
User have to select a directory from the Tree view below and this path should be shown in the "DataDir" text field.
I tried it with "Reveives from Written variable value" for the text field and setup "set variable datadir to" before calling the dialog.
But there is always a direcotry path in the "DataDir" at the start time.
Can you tell me how I have to set the variables and settings in the dialog?
thanks a lot
Hansjoerg
