Wen cancelling an install a strange dialog shows
smeyn
Post by smeyn »
When I run an install I built with V11 R2 and I hit the cancel button during the apply install I get a dialog pop up with the question "Old File Date:?" when it should probably say "Cancel Install?" or such.
Anything I can do about this?
smeyn
Re: Wen cancelling an install a strange dialog shows
Post by smeyn »
Also the components tree has funny labels:
somehow the indexing to labels seems to be wrong. Can I fix this myself?
smeyn
Post by smeyn »
Also when the installer starts up I get this dialog:
which I think is not supposed to display an error message (as no error occurred) but is supposed to say something like "Extracting archive file" or such.
And when I bring up the splash screen of the Installaware application I noticed it actually says Release 9 ?????
Is there a new update coming soon? I can't have users see error messages when there are none.
giaviv
Post by giaviv »
It is very strange you are getting these error messages. Something must have messed up your installer shared strings.
Try creating a new project from a template (basic setup for example). Are you experiencing the same thing?
If so, please uninstall InstallAware and install it again.
smeyn
Post by smeyn »
THe issue has been resolved. I was using the wrong licence key for a prior version. Using the right licence key fixed it all up.
