I have created an install package that should copy 2 of the newly installed files from the install location of the app location here is the command I used :
It could depending on the value selected on one of the interview screens copy one of 3 different files
if Variable xxx13Installed Equals (Ignore Case) True
Copy Local Files $TARGETDIR$\addons\xxx13\Interop.xxx.dll to $TARGETDIR$\Interop.xxx.dll
The files are in the addons\??? folder but are not copied to the TARGETDIR folder.
What I would like to know is where is the installer log file located if there is one. I would like to
see what the xxx13Installed variable is and also if there was an error, and what it is.
Paul
Log file location
Re: Log file location
Paul,
Use the LOGGED predefined variable for the log file location.
My guess is that you are not using the Native Engine - therefore, all install / copy commands you call go into a queue and only actually run when you call apply install.
Please turn on the Native Engine and that will most likely solve your problem (Set Variable NATIVE_ENGINE to TRUE).
BlackNight
That worked..
Thank you!!
Is there place on your site that tells me what changed between version 10.10 and the latest version 2012?
Why should I update to v2012?
Thank you!!
There you go:
http://www.installaware.com/news-installaware-2012.htm
