i cannot create a patch for my projects, it allways uninstalls the previous version and then fails with the "system cannot find the file specified" error...
Patching and Previous Version Uninstall
Regards,
Michael
Michael
Re: Patching and Previous Version Uninstall
Dear Michael,
I understand that my answer may seem obvious, but I suppose there is a problem with your project.
Have you followed the instruction reported at: http://www.installaware.com/publication ... guides.htm with the file "Using InstallAware to Patch Software Products"?
I suggest to you if you still have problem, to start a simple project as described in the above document and see if you still have problem.
Hello Francesco,
for some reason, when i opened from the UI the Project Properties-> Compiler Variables, the list was filled with attributes used by the compiler in order to build the project.
Among them, there was the BUILDMODE variable set to CD... I think that although i was building a Patch from the ribbon command, that variable did not change...
I deleted all of the compiler variables from that window, i only left the CACHESOURCES=TRUE and now when i build a patch at least it does not prompt me to uninstall the previous version...
I don't know why the IDE got confused with the variables, you should check if there is a bug on that area.
I am reviewing all the script in order to succees with the patch. If i encounter more problems, i will update or post a new topic.
Regards,
Michael
Michael
