Converting InstallShield. SalvationShield.dll access viol.
mhammady
Post by mhammady »
I'm trying to convert from IS 2012 Pro to InstallAware RAD studio Edition. After creating a new project, and try to import the *.ism file, i get the attached access violation error in the SalvationShield.dll
Kindly advise what could be wrong??
BR
M. Hammady
Re: Converting InstallShield. SalvationShield.dll access vio
The InstallAware InstallShield converter only works on InstallShield projects saved in XML format.
Please save your project as XML and try the conversion again.
A_Ivlev
Post by A_Ivlev »
I have the same exact problem, trying to convert a project from InstallShield 12 Premier Edition.
I don't see any way to save the project as XML in IS12. It only offers *.ism and *.ist formats. How do you save an InstallShield project as XML?
For what I know it is just required to save InstallShield projects in XML format.
I do not know if this can be related to an InstallShield edition limit.
Probably you can have more info on InstallShield Forum.
