Problem with windows profile
andcrumx
Post by andcrumx »
I have an installation project which in 10% of the machines to install, windows lost their profile. Is it possible for a bad configuration in the installer?,Do you have any similar case reported?
Thanks!!
Re: Problem with windows profile
For what I understand from your message, I am not personally informed of similar problems.
When you say
, what do you exactly mean?
Note that InstallAware generates installations processes essentially transparent for the OS and this usually, does not cause degeneration of the system, unless those have been erroneously or intentionally introduced.
