It appears to me that when I select an “Application Runtime” from the “Application Runtimes” section, InstallAware appears to make *copies* of the source application runtime scripts and puts the new copies next to my InstallAware project (mpr file).
So my question are:
1) Are the script completely independent copies from the source scripts?
2) What happens if I modify the scripts on my project? Would InstallAware undo my changes if for example there was a fix to the script authored by InstallAware? In other words, will InstallAware detect that there is a newer version and automatically overwrite my local copy?
3) Is it possible that for some reason InstallAware would modify the source scripts with changes I make to my local copies?
Application Runtimes Local Scripts
Re: Application Runtimes Local Scripts
for what I know, I have never anything like occurred.
Are you able to reproduce it in any way?
rxelizondo
Reproduce what? I was asking a question not reporting a problem.FrancescoT wrote:
My response was already in my previous message.
Then I asked that question just to be sure that you did not have a problem, that's it.
InstallAware do not replace automatically your existing script project. Unless you do it.for what I know, I have never anything like occurred
