Variable not defined: MDAC28
jcutting
Postby jcutting » Wed Jun 14, 2006 7:00 pm
On IA6 Studio I am getting a compile error on line 6 of setupmdac28 when I include the MDAC 2.8 runtime:
If I remove the runtime the error goes away.
How do I get past this?
Jonathan
Postby MichaelNesmith » Thu Jun 15, 2006 8:58 am
Your include scripts may be out of date. This is how the correct script looks like:
Set Variable MDAC28 to TRUE
Check/Install MDAC Refresh (check v2.8, get result into variable MDAC28)
if Variable MDAC28 Equals FALSE
  Set Variable PREREQ to TRUE
  Set Variable PRELIST to $PRELIST$$NEWLINE$Microsoft MDAC Refresh 2.8
(This is checkmdac28)
jcutting
Postby jcutting » Fri Jun 16, 2006 3:27 pm
That's what I see in my checkmdac28.mia file. It's still giving the same error. Is it possible that something has been corrupted?
checkmdac28.mia
Postby MichaelNesmith » Fri Jun 16, 2006 6:34 pm
Maybe the variable is in use at some other place before it has been defined?
I'd replace each Include Script command in my setup script with the actual contents of the include scripts shown in the IDE to nail down the problem.
jcutting
Postby jcutting » Fri Jun 16, 2006 7:17 pm
I think I figured out what was happening. I created a new runtime based loosely on the MDAC28 check/setup scripts. I should not have copied and then modified the mia files - I think the compiler was choking on duplicate GUIDs. I manually recreated my check/setup scripts by typing in the IA6 IDE and everyone is happy now.
Postby MichaelNesmith » Sat Jun 17, 2006 6:28 am
Yes, that would explain it!
Users browsing this forum: Google [Bot] and 45 guests
