Web Update delete files
UltraTM
Postby UltraTM » Tue Feb 12, 2013 9:20 am
i have a programm to install.
Update 1.1 adds 2 Files and should remove 2 other files.
The Update will only add the other 2 files. but not delete the old one.
They dont have the same name.
Can someone help me plz?
Thank you very much
Re: Web Update delete files
Postby FrancescoT » Tue Feb 12, 2013 10:01 am
are you sure those files are not in use during upgrade process?
the upgrade process correctly removes previous installation before to proceed?
is it the update correctly reported in Control Panel -> ARP after installation?
UltraTM
Postby UltraTM » Tue Feb 12, 2013 10:59 am
Hello Francesco,
thanks for your reply.
I made a Web Deploy with InstallAware 15 Studio Admin.
the .7zip file loads from webserver.
Update is set in Update Packs and Version.
Created with Design > Deploy > patches and used the compiled exe from web deploy of version 1.0.
Then i closed InstallAware. Deletet 2 files and added 2 files in the Source folder.
opend InstallAware and createt the patch.
what i have too, is he updatees more files that are already in Version 1.0 and nothing changed. This are txt. Files
now when he loads the patch and installs it. I have the 2 new files inside but the 2 old files with a other name are still in there.
What you mean with reported in Control Panel > ARP?
Thank you
Postby FrancescoT » Tue Feb 12, 2013 11:25 am
You didn't say that you are installing a Patch ... I supposed you was running a full update.
Please first verify that your patch project has been created correctly.
There are some rules to follow with a patch project and I suggest you to have a look at the following forum topic, where a patch sample project it also available.
http://www.installaware.com/forum/viewtopic.php?f=2&t=9343
The information reported in Control Panel -> Add Remove Program list about your installed application.
UltraTM
Postby UltraTM » Tue Feb 12, 2013 11:58 am
i also made it like this link:
http://www.installaware.com/installaware_patching.pdf
It works patching but not remove the old files. Everthing is fine.
i only need help why the Program dont remove the 2 deletet files.
With the sample Project on this Topic i added in Version 1.0.0.0 a test.txt
and in version 1.0.1.0 only the updatet pdf.
Pdf is updatet but test.txt
not deleted?
You now know what i mean?
What should i have to do to delete files with update i want to
Thank you very much
UltraTM
Postby UltraTM » Wed Feb 13, 2013 3:09 am
Can you please help me with that little thing up there?
I readed every post tread and.pdf from whitelist link.
But nothing how to remove files with update only update files and add.
Please help me. The only thing now before publishing ma program to make money with it :(
thank you very much Francesco
Postby FrancescoT » Wed Feb 13, 2013 8:32 am
Could you please post a very minimal project that replicates you issue?
In you specific case should be two projects;
- one for the first installation version and the other one, which contains the modifications you want to apply to the installed application.
I believe this is the preferable way to find out what really happens on your side.
Post the projects (in compressed form) with your reply when you ready (please include the two complete project folders and all the files used).
UltraTM
Postby UltraTM » Wed Feb 13, 2013 8:37 am
I attached your sample Project modified.
In Version 1.0.0.0 it installes the .pdf and the test.txt
In Version 1.0.1.0 it should remove the test.txt (not working) and updates the pdf (working)
Best Regards René
Test.zip
(5.27 MiB) Downloaded 469 times
Postby FrancescoT » Wed Feb 13, 2013 8:39 am
Dear René,
I'll will be back as soon as possible.
Reagrds
UltraTM
Postby UltraTM » Wed Feb 13, 2013 9:04 am
Hello Francesco,
ok thank you.
When you find the bug or setting i missed for it to get work tell me please :D
UltraTM
Postby UltraTM » Thu Feb 14, 2013 8:15 am
Hope you can help me today.
Tried it a all time again in hope to find my mistake. But always the same. Dont delete files
Postby FrancescoT » Thu Feb 14, 2013 9:18 am
Dear Rene,
The projects you uploaded do not contain your modification, but instead are the exact copy of my samples.
Anyway, I have modified them for you ... and the patch build "Version 1.0.1.0.exe" removes the text file and replaces the pdf installed by version 1.0.0.0.
Hope this clarifies your doubts.
NOTE;
the attached file already contains the packages builds. If you want to rebuild the project for version 1.0.1.0, you must modify the patch reference path with one available with your environment.
rene.rar
(5.18 MiB) Downloaded 499 times
UltraTM
Postby UltraTM » Thu Feb 14, 2013 10:23 am
Can you explain what you did for the project?
Postby FrancescoT » Thu Feb 14, 2013 10:26 am
Dear Rene,
just added the txt file installation in project 1.0.0.0 and then in project 1.0.1.0, added a "Delete File" command if compiled as PATCH.
That's it.
UltraTM
Postby UltraTM » Thu Feb 14, 2013 10:36 am
Hello Francesco,
YES thats it. i love you so much :)
it works. That was my mistake didnt added files to delete Local Files.
Great Support here. You helped a lot.
Thank you very much :)
Users browsing this forum: No registered users and 97 guests
