I want to setup Features structure in which one feature has two sub-features which are mutually exclusive.
For example, suppose I have Feature 1 and also Sub-Feature 1 and Sub-Feature 2 under Feature 1 as per attachment. Sub-Feature 1 is initially selected.
Now if user selects Sub-Feature 2 then Sub-Feature 1 will be deselect and vice versa.
How can we do this?
Regards,
Chintan
Mutually Exclusive features selection
chintanpatel7
- Features structure
- attachment1.jpg (18.31 KiB) Viewed 6095 times
Re: Mutually Exclusive features selection
Dear Chintan,
unfortunately, it is not possible to handle it with a "Dialog Control Object Behavior" Rule.
I ran into this issue myself and it required me to rethink the design flow of my installation, unfortunately the end result isn't as clear to the user (or simple) as it would have been if this type of configuration would of been possible.
I will try to log a feature request for it ... i can't guarantee, but I will try.
