Has been happening since IA 10, Dialog shows up white
ckaware
Post by ckaware »
Why would this be happening!?!
When you proceed with installation, occasionally a screen shows up white (all objects are not displayed.)
When I click previous to go back to the Choose Folder Dialog I see the following (attached).
If I drag the window off and off the screen it refreshes.
This has been happening since IA 10. Why? (even the cancel button disappears)
CKAWARE
Weird screen issues with IA (This was on Win 7)
Re: Has been happening since IA 10, Dialog shows up white
Dear CKAWARE,
honestly, I don't know.
If you can send a very minimal project (... including just the dialogs you used), I will try to verify it.
ckaware
Post by ckaware »
I've sent you an email with a project, the dialogs.
I have tried turning Glass off, I've tried removing that background image and it still happens.
I've seen this (as well as customers) on Windows 7/ Windows 8...
To fix the issue as it occurs you literally drag the installer off/ then back onto the screen.
Chris
I received your file.
will be back as soon as possible or if I require any additional info.
ckaware
Post by ckaware »
FrancescoT wrote:I received your file.
Thanks Francesco,
It's mind boggling as to why this is happening.
Chris
ckaware
Post by ckaware »
So this is happening when Windows is using visual themes/ styling. If I turn off AERO themes etc. it will not have this refresh issue.
Dear Ckaware,
as I already told you by email, the problem is caused by one of your dialogs.
If you replace that dialog ("clicustom"), with any other dialog, your package works fine.
I suspect exist something with that particular dialog resource causing the issue (... probably the dialog resource file is corrupted).
bertclark
Post by bertclark »
Having the same problem....has anybody found the solution!! :(
as I said with my previous reply, the issue reported by Ckaware seems to be caused by a dialog resource used by his project ( ... maybe corrupted).
If you believe that this doen't apply in your case, please provide a very minimal sample project that replicates the issue and I'll verify it.
ckaware
Post by ckaware »
I figured it out!
One of my dialogs had the formstyle set to fsStayOnTop I changed this to normal and it now works :).
CKAWARE
... very very happy that you solved :D :D :D !
