help needed with patches, upgrades, updates
CirrusPilot
Postby CirrusPilot » Wed Jun 21, 2006 9:50 pm
I can't get the patching mechanism to work, probably because nowhere that I can find in your help do you ever mention what files need to be uploaded to my server. I know the .ini file has to be there. What else?
Do I upload the entire Patch folder? The Upgraded Package folder? Something else?
Some concreteness in the documentation would be very helpful. And this seems to be a recurring problem in this application. For a $900 product, I expect much more in the way of useful documentation, especially for a version calling itself "6".
Following various hyperlinks around doesn't paint a complete picture. You should seriously think about creating use cases that walk users through an entire process such as creating an initial version and then updating it.
Not everyone's an expert. And those of us migrating from other platforms that don't rely on MSI could really benefit from extended help.
Thank you.
Gizm0
Postby Gizm0 » Thu Jun 22, 2006 2:45 am
The patching mechanism does not require any kind of .ini files to work.. I guess you are reffering to the update mechanism..
Panagiotis Kefalidis
Software Design Team Lead
Postby MichaelNesmith » Thu Jun 22, 2006 6:08 am
Please press F1 in the following IDE views:
Application Information->Project Properties
Deployment->Patches
Web Updates->Update Packs
Web Updates->Versions
And you will have context sensitive help assisting you with your problem.
CirrusPilot
Postby CirrusPilot » Thu Jun 22, 2006 11:06 am
I've read the manual and the online help and they didn't answer. So my question is this:
Out of the patch folder, what needs to be uploaded to the server?
Thanks for your help.
Postby MichaelNesmith » Thu Jun 22, 2006 6:53 pm
That depends on what you are doing with the web update mechanism.
If you want to serve a patch as a web update to your customers, then you will need to upload the patch folder to your server, and create an update pack referring to that uploaded patch, and then associate that with versions that you want to update - and finally upload the latest INI file used for the update.
Tinus
Postby Tinus » Fri Jun 23, 2006 2:14 am
I agree with CirrusPilot. A good example is missing here.
Why not add a walktrough of patching/updating into the document
"Using InstallAware To Deploy Microsoft .NET Framework Applications"?
http://www.installaware.com/installaware_deploy_dotnet.pdf
Martin Rothschink
AxoNet Software GmbH
Postby MichaelNesmith » Mon Jun 26, 2006 5:51 pm
Cirrus -
I think part of the problem here is you are building patches in debug mode. When you normally build a patch, only one file exists in the patch folder!
Tinus -
Thanks for your suggestion, we'll be coming out with more guides soon.
Tinus
Postby Tinus » Tue Jun 27, 2006 1:57 am
MichaelNesmith wrote:Thanks for your suggestion, we'll be coming out with more guides soon.
Great! A good and detailed example answers many questions and helps a lot to get the complete picture.
Martin Rothschink
Users browsing this forum: Google [Bot] and 46 guests
