Help Me Pitch IA
jdeleon7010
Help Me Pitch IA
Postby jdeleon7010 » Thu Oct 24, 2013 8:27 am
I have demo'd InstallAware and InstallShield. Coming from a wise scripting background, I believe IA will be the easiest transition to make to rebuild all of our wrappers.
One question that was brought up was, what is the adoption rate of IA vs IS? What well known enterprise uses IA in their environment?
Would it be beneficial for us to invest in training for InstallShield as it has been around for a while and is used by major IT companies out there?
We don't build MSI applications, we just repackage third party apps, which makes IA the best choice for us. But I am running into a valid case as to why we should invest into IA.
Re: Help Me Pitch IA
Postby FrancescoT » Fri Oct 25, 2013 11:01 am
Dear jdeleon7010,
First of all, thank you for your interest in InstallAware products.
However, probably if I tell you that InstallAware is an easy to use product or an amazing tool ... I would certainly be accused of not being impartial.
I may suggest you to take a tour of our forum, in order to verify the mood of our users in InstallAware.
Of course, I can assure you that IA is the easiest transition from Wise ... I have been a Wise user as well.
In addition, I suggest you to have a look at our available publications and to directly test the available samples (ready to use) included with the IA trial.
Return to “Non-Technical”
Users browsing this forum: Google [Bot] and 6 guests
