No files matching wildcard pattern using relative build fldr
tofutim
Post by tofutim »
When I use a relative path for the Custom Build Folder, The File Bag Plug-In complains that it cannot find the .NET runtime, even when the Web Media Blocks are set to not build. It is not a problem when the file path is absolute.
Re: No files matching wildcard pattern using relative build
Dear Tofutim,
... only absolute paths are allowed.
tofutim
Post by tofutim »
Feature request then. It would be good to be able to check-in IA setups and use them in different environments.
... I know that it seems an easy thing to do, but it not unfortunately.
That's the reason why it is not available!
