Using a component in a feature tree for grouping, displaying the required space for its child components
Kostya
Postby Kostya » Fri Aug 09, 2024 4:57 am
In the feature selection tree, it is possible to group components:
Define Component: Additional Components
Define Component: Additional Components\Component 1
Define Component: Additional Components\Component 2
Is it possible to make it so that when selecting the "Additional Components" node, the required space labels would display the space occupied by the child components? That is, so that the parent component would be used for visual grouping only.
Additional Components << Selected
|__[V] Component 1 (2 MB)
|__[X] Component 2 (3 MB)
Required space: 2 MB
Total required space: 2MB
I see that I can set the parent size to "0", this will not affect the value of the total required space. But then, when it is selected, the value "0 bytes" will be displayed. And I would like to achieve that as a group it displays information about the size of its child components.
Kostya
JohnGaver
Re: Using a component in a feature tree for grouping, displaying the required space for its child components
Postby JohnGaver » Sat Aug 10, 2024 4:57 pm
Have you checked InstallAware Multi Platform's console mode (pure command line) setup engine?
I believe that might be working in this way, it looks very similar to what you have drawn here.
John Gaver
InstallAware Skunkworks
Kostya
Postby Kostya » Mon Aug 12, 2024 6:37 am
Hi John,
If you mean what it looks like here, where the console displays a structure indicating the required space, then yes it looks like that.
We are using a relatively old "InstallAware Studio X6 Creators Update", but we have the latest version too. That's what I'd like to understand:
    1)Could we achieve this with the current version or a newer one, but not in console mode?
    2)If this is not present when using the UI mode in the latest version, can we expect this feature to be added? (X components selected from Y, required space for sub-components is Z MB etc. Or like in console mode, in parentheses.)
Kostya
JohnGaver
Postby JohnGaver » Tue Aug 13, 2024 6:19 pm
Thrilled to hear that helped!
1) The console mode setup engine is currently only available with InstallAware Multi Platform.
Regardless, you really shouldn't be using X6 - it is old and has known security vulnerabilities. Since you already have an X16 license, there really is no rationale to not upgrade to our latest, greatest, and secure version right away!
2) I've already added in a request, but R&D would not commit to any time frame - until features have been signed off and have become publicly available.
John Gaver
Kostya
Postby Kostya » Wed Aug 14, 2024 6:44 am
John, thanks for your reply! We will upgrade to the latest version, and I really hope that the described features will appear soon.
Users browsing this forum: No registered users and 89 guests
